I'm trying to get three drawings of the same image (at different scales) sent off to the laser printers, who will put them on a single 600x900mm MDF.
I've attached the file I sent them, but this image is basically what I mean (the white paper dimensions are 600x900mm)
I set up the page, and inserted the drawing three times at 1:1000, 1:500 and 1:250. Red lines are where the MDF is to be cut, blue lines are for laser.
However I've had it sent back to me, saying it needs to be in the model space, not the layout space.
I'm completely clueless and I've had a back and forth email over this issue for about a fortnight now. I'm a student who's doing all my learning from home, and I'm getting no pointers from the uni about how to do this, just basically being told that they won't cut it until I sort it, so I'm really falling behind with my project.
A 600x900mm rectangle in the model space would be absolutely tiny since the drawing is 1:1.
Please can anyone help?? Thank you so much
Solved by Alfred.NESWADBA. Go to Solution.
take a look to command _EXPORTLAYOUT (>>>details<<<).
- alfred -
Thank you so so much, I can't believe it was that easy! I really appreciate your help
