My xref base moves every time I reload it
anita6LE92
Message 1 of 12
anita6LE92
I have a floor plan that is xrefed into several other drawings and has items added to it in each of those drawings. Every time a reload it or open it again, it has moved and only the added items are visible.
Replies (11)
Message 2 of 12
duranNRBQE
Observer
Observer
Message 3 of 12
ennujozlagam
try VISRETAIN command?
Message 4 of 12
anita6LE92
see attached files.....
Message 5 of 12
ennujozlagam
here
Message 6 of 12
pendean
Community Legend
Community Legend
@anita6LE92 wrote:
...Every time a reload it or open it again, it has moved and only the added items are visible....
Thanks for the filesx2, how exactly do we replicate your issue? Which file should we be in, which exact steps do we need to follow, which XREF(s) do we do what to etc. please.
And is this deliberate?
Message 7 of 12
anita6LE92
It is supposed to have the floor plan that is in the bottom right of the xref underlaying all the tags that are entities in the current drawing. The two parts, xref base and existing tags are supposed to be in the same place when you open the drawing but even though I correct the location by moving either the tags or the xref, the next time I open, it is in separate places again. See attached for how it should look when it works correctly.
Message 8 of 12
pendean
Community Legend
Community Legend
@anita6LE92 Thanks or the new PDF: someone set BASE command in the XREF file to something other than whatever it used to be (the default 0,0,0 is not quite it, but it gets close).
Then someone in the top file then decided not to drop the XREF at 0,0,0, but did a manual move somewhere far away (see below, Top file then the XREF)
Since AutoCAD does not keep a historical list of what got moved/changed where by default, it's hard to tell what needs to go back where from what I can tell. Maybe someone else can figure it out for you around here.
It may just be easier to fix it now, once, and examine why BASE command needed to change.
Summary: someone deliberately edited the default insertion point of your XREF. perhaps to fix the topfile's problem.
Message 9 of 12
anita6LE92
it looks like the upshot is that the base point somehow got changed to another coordinate than 0,0,0. I have changed it back and problem solved. Thanks very much everyone. I had totally forgotten there was such a thing as a base command.
Message 10 of 12
jay_colcombe
Is this file being used to link into Revit by any chance?
Jay Colcombe
Autodesk Certified Instructor
Message 11 of 12
anita6LE92
no it is not associated with Revit in any way.
Message 12 of 12
jay_colcombe
Thanks - I know when ACAD models are linked into Revit and Shared Coordinates are used it can resave the coordinates back to the CAD file moving the Base UCS very annoying!!!
Jay Colcombe
