My F9 key doesnt work right
jriseborough
Message 1 of 9
jriseborough
My current F9 when I press it, windows file explorer opens. In the CUI, F9 is snapmode.
Not sure how to get it to work right.
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
You are either on a laptop or a specialized 3rd party wireless keyboard, yes?
You might have forgot to study your keys if so
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/F8-function-key-do...
Message 3 of 9
jriseborough
Other F keys work fine. F8 toggles ortho. F10 toggles polar. F9 opens an explorer window.
Message 4 of 9
pendean
Community Legend
Community Legend
So this is NOT a laptop or a specialized keyboard? Then you have something in your AutoCAD (add-on or startup) that is changing that for you, regardless of what your CUIx is showing: did you purchase or add something recently?
AND... did you restart your computer yet?
Next steps are to reset of your AutoCAD (you'll have to backup your customizations first, test without restoring them to confirm the issue is gone, then when you reload your customizations and the issue reappears then you added something to do that).
Message 5 of 9
jriseborough
It is a laptop.  Its been doing this for a while, and just really is getting annoying. My F3 and F9 open up explorer, everything else seems to be default.
Nothing recently installed.
I can live with it, not gonna go thru the trouble on installing autocad again. Just thought it would be an easy fix.
Message 6 of 9
paullimapa
You can try starting AutoCAD in safemode just to see if this is caused by an addon
Paul Li
IT Specialist
@The Office
Message 7 of 9
jriseborough
No change.
Message 8 of 9
pendean
Community Legend
Community Legend
No change.
Message 9 of 9
paullimapa
In case you’re confused reset is not the same as installing
Paul Li
IT Specialist
@The Office
