my cad does not copy drawings from another cad file
my cad does not copy drawings from another cad file, when I try copy a drawing or a block my cad locks and don't paste.
Vinayv4v
Attach a screen shot or a screen cast.
May be the blocks or drawing you are trying to copy maybe in a locked layer.
To test this
Just open a new drawing > draw any objects.
Ctrl+C (Copy) those objects > open a new drawing > paste it there.
If this works fine then your issues may be different.
Cheers,
Vinay Vijayakumaran
How are you copying the drawings/blocks? Are you using the ADCenter or copyclip?
Hi arq.patricialrodrigues,
What version of AutoCAD do you have and what paste function are you using?
BeKirra
Copy clip is the one you should use.
"Crtl + C" to copy geometries from one drawing.
"Crtl + V" to paste geometries to another drawing.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
ennujozlagam
@Anonymous try COPYBASE
