multiple drawing sheet conversion in to PDF
Message 1 of 17
Dear sir,
Have a nice day!
 i am using AUTOCAD 2014 in that i design some electrical schematics for the college project i draw the multiple drawing on a single sheet now i want to convert each sheet into a diffrent PDF is there is any solution through which i can select 10 drawing from a single file and publish it to a different PDF or i have to do it one by one please help on this.Am a beginner in the Autocad your help will be advantageous to save my time
Samrat
Replies (16)
Message 2 of 17
ennujozlagam
hi, i think you can only do it one by one manually. thanks
Message 3 of 17
there is no any alternative?
Message 4 of 17
what in case if i have 100 of layout on a single sheet?
Message 5 of 17
massimo.corradi
You can use the publish command if you have each sheet on a separate layout, this is the way how it's meant to work by design (check also "page setups" in that case). If you have put all sheets on one layout you would need to select "by window" each sheet manually or you would need to wite a script to automate that. ...Or maybe, if you are lucky, you can find something that does that already in the app shop.
Message 6 of 17
thanks i will check it out and let you know the status soon.hoping it will be available with a readymade solution.
Message 7 of 17
HI,
Can you please help me to sort out the above issue please find enclosed attachment for the detail Attach is the autocad 2010 file where i draw a multiple drawing  on single sheet is it possible in autocad to convert this drawing into PDF in a single procedure right now am converting it inot PDFwaht i have to do is using "window"option in PUBLISH box and select the perticular sheet area and then publish it into the PDF which is very time taking
Can anybody show me the short cut for the same for that i attach the trial file of DWG
samrat
Message 8 of 17
TheCADnoob
What you will need to do is create a seperate paper space for each "drawing." It might be helpful to name the tabs according to the contentent of the individual drawings as well.
open the layout and ZOOM WINDOW to each of the different drawings
Once you have done this for all your drawings go to batch pplot
From the batch plot dialog select only the drawings (now the new layouts you created) you wish to plot
and simply publish. If you need individual dwgs you can select multifile in the publish options dialog
once this is done creating what you needs is easy
CADnoob
Message 9 of 17
Thanks ,
But can you please elaborate how to create a seperate paper space for each sheet. am beginner in the autocad so can you explain the procedure for crating a seperate paper space
samrat
Message 10 of 17
pendean
Community Legend
Community Legend
They already explained it: try to follow the screenshots they posted and download the PDFs they posted in their reply.
Message 11 of 17
TheCADnoob
this is fairly rudimentary, you may need to take in some tutorials to help you get along with the program.
first create a new tab
Next open that tab. double click the paper and change your viewport size. Next double click within the viewport and type zoom > window and select your drawing.
CADnoob
Message 12 of 17
dbroad
The previous posters have showed you the preferred way to setup a drawing for multiple plots.  You have a single modelspace (not sheet) in which you layout multiple sheets.  You can also setup multiple page setups in model space and publish the setups as part of a new sheet set.  I estimate that it would take you about 10-15 seconds per sheet to setup and would not add an excessive number of layouts to your drawing.  It is challenging to manage more than 20 layouts per drawing file.  See screencast.  If you were to create a template drawing with the grid as noted and setup a sheet set file for that template, any additional drawings would take much less time than the first setup.
Architect, Registered NC, VA, SC, & GA.
Message 13 of 17
THANKS Dboard it give me extreme clarity of publishing a PDF it save my much time thanks for your valuable guidance
Samrat
Message 14 of 17
thanks CADnoob for your valuable guidance
REGARDS,
SAMRAT
Message 15 of 17
TheCADnoob
glad to have helped. Smiley Happy
Please select the reponse that best solved your problem and mark it as the solution so that others may be able to find it in the future.
CADnoob
Message 16 of 17
thanks for helping me to resolve this issue.
samrat
Message 17 of 17
up but its time taking am looking forward to save my time for publishing PDF. am looking forward to get lisp file so it saves my time more than the current one
Samrat
