Multiline text with multiple fields in block
nagarajandesignengineer
Hi all,
Herewith attached One Image (To be Considerd as `Block') has 6 attributes.
In this Block, I want to merge their value of Att-3,4,5 in one Multiple line text with 3 insert field (objects_value).
Can any one guide me how to prepare this block pls
When i tried , In multiple line text shows ` _______ ' only, So Kindly
Thanks in advance
@nagarajandesignengineer - moderation edited title for clarity. (original: Multiline test with multiple fields in block)
will_young
I just tried this and got the same result with the ---- when I made a multi-line attribute and the other 2 lines as fields. However it works if all 3 lines are fields which reference hidden attributes:
Importantly, the value of the referenced attribute must be empty:
Once created, the attributes must have a value otherwise they show ----.
In this case you can add a . or use a blank character:
Thanks, Yes its Possible , But i need what i required one . So i am trying to get eagerly.
