Is this stil an issue multileader not matching the layout?
I created a text style that should match orientation of layout and is included in multileader but it does not work!
Solved by BrianBenton. Go to Solution.
Something like this, please see the pic!
When there is a new UCS for Viewport the multileader does not match the Viewport!
Multileaders don't have this functionality. Text styles do. You will need to rotate your view in model space and place your leaders there, or place your leaders through the viewport in floating model space in your layout. Or place your leader, then rotate the text in the properties.
Thanks!
I picked the one with placing mleader in model space in rotated Viewport!
Thanks!
