Multileader block circle textstyle
krkec
krkec
When using multileader with Block (circle) instead Mtext the textstyle should be the current selected, but that's not true.( see attached jpeg). I set default text to Romans but text is still in Arial. Anyone with a good solution here. Thanks a lot!
vinodkl
Hi @krkec
Its not a mtext inside the circle block used in multileader, its an attribute. Changing the text style would not change the text style of the attribute inside the circle block.
When you created the multileader with a block then the circle block will adapt the current text style set for the attribute inside the block and when you again change the text style it would not reflect that to the attribute inside the block and it would remain with the same text style as in your case i.e Arial.
If you would like to change the text style of the attribute inside the circle block then you need to do it manually. Type in the command "BEDIT" and select the block "_TagCircle" and when inside the block editor select the attribute open the properties(ctrl+1) and change the text style to "GP-Romans" and save the block. Now you would see the circle block would have changed the text style🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
donanthony.virola
Community Visitor
Community Visitor
