multileader arrowhead
When I use a multileader in a base drawing and xref the base into another file to plot, the arrowhead (dot) shows up when plotting. it is not visible, but it shows up in the plot. why doesn't the arrow have the same properties as the leader and not show up?
pendean
Community Legend
Community Legend
Freeze instead of "off" that layer and see if your issue goes away.
Thanks...but no.
The leader is on a frozen layer.....Just the arrow is plotting.
It is not even visible. It only shows up in the plot file (PDF)
MARK D. MCLEAN
AIBD - LEED AP
PROJECT MANAGER
mark@harrellarchitects.net
O: 239.435.1250
C: 239.250.9915
pendean
Community Legend
Community Legend
I can't replicate at all: is this a custom arrowhead? Can you share a portion of a DWG file with this problem present? What PDF driver are you using?
TheCADnoob
as @pendean asked, is this a custom arrorw head. If so there may be elements of the block that are on different layers causing the issue.
CADnoob
wwork
The problem is with the definition of _DotSmall. I was able to resolve the problem by opening _ArchTick in the block editor and recreating the _Dot Small graphics. Then I used BSAVEAS to redefine _DotSmall.
codyCQN3K
Yes this worked for me.
