Ok, I am pursuing purchasing a Autocad 3-user package and am slightly confused in the following message:
With a subscription to AutoCAD software, you can install it on up to three computers or other devices. However, only the named user can sign in and use that software on a single computer at any given time.
I just need a simple answer for I am totally new to this.
Is it just one person can access Autocad With the 3 user licence or does it cater for 3 different users to access the software simultaneously? Just clarity before I commit and invest.
I need 3 persons to access the software simultaneously (putting it in a nutshell)
Best regards
Solved by DarrenP. Go to Solution.
Solved by dmfrazier. Go to Solution.
A 3-user license allows three different users to access the software concurrently.
Each user can install the software on three different devices, but may access it on only one of those devices at a time.
if you getting 3 licenses of Autocad that means 3 different users
each user needs their own Autodesk Account
DarrenP
You’ll have 3 users who can access the software and each is assigned using their email
