AutoCAD Forum
Multi-Text
1 REPLY 1
330 Views, 1 Reply
Multi-Text
During the use of Autocad 2015 the option to adjust the paragraph is not there. So if you move your moude over the dinamd in te upper right corner at the start of the day would let you adjust the size of the paragraph. This pic is when it will not allow you to Change it any more. Any thoughts?Capture.PNG
1 REPLY 1
Sergio.Bertino
Hello pwalker,
Thanks for your post.
I understand that you cannot move the diamond on the upper right corner of a multi-line text, but only after some time, at the "start of the day" it works fine.
Well, I tried on my machine and I cannot replicate it, do you know if there are some steps to follow in order to replicate it?
Sergio Bertino
MFG Technical Support Specialist
State of Sustainability Webinar
AutoCAD Inside the Factory
