Multi page scaled pdf plot without creating layout
This widget could not be displayed.
I am wondering if there is a quicker way to plot multipage pdf. Creating layout takes lots of time as there are like 50 of them. Batch plot/publish needs layout.
But I am looking for a way without layout.
Replies (18)
Alfred.NESWADBA
How should AutoCAD know that you need 50 plots if you don't have 50 layouts (prepared with page settings, border, format, scale, ...)?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
That's what I am asking bro. If there is a way.
Alfred.NESWADBA
Yes, development 😉
And when we know how your data is structured, it might be easier to give a global answer like yes or no (without a bit sarcasm) 😉
- alfred -
Alfred NESWADBA
jackshield
50 of them ... hmmm
50 of what?
about 50 pages to plot from 1 drawing
jackshield
Is it all in model space?
Sent from my iPhone
Yes, all in model space. Its basically 1 large map of a city (sadly I don't have the rights to share) . I need it to plot in about 50 pages.
Alfred.NESWADBA
Well, we got an info about the drawing content and what you'd like to do.
So do I understand that correct that you have a map, and you need to split this map into rectangles and plot then rectangle-by-rectangle?
Do you have plain AutoCAD or do you have Map 3D or Civil 3D (because these products have functions to do jobs like I guess you need).
- alfred -
Alfred NESWADBA
Yes, exactly! Its drawn in plain Autocad. But I have civil 3d installed too. If I open the dwg with civil 3d is it possible? Please let me know how. Thanks
Alfred.NESWADBA
Yes, look to the command _MAPBOOKCREATE (>>>details<<<).
It's a one time hard learning time, but knowing how it works makes it a very powerful tool.
- alfred -
Alfred NESWADBA
I can't generate the layouts. Saying this, "layout does not have title view element specified"
I used the attached template.
No way to do that in model space AFAIK. This is what paperspace is for...
jackshield
read the other responses?
This is the settings I used. Please let me know what is causing the problem
Alfred.NESWADBA
Start with a default Map3D template like "Map Book Template - 34x44 Classic.dwt" so you have at least a valid template.
When you get your drawing working with that template then start to modify this until it meets your needs and Map3D can use it.
- alfred -
Alfred NESWADBA
I see. So Plain Autocad template won't work? Only way is to customize existing ones?
Alfred.NESWADBA
They have to follow rules, otherwise they can't be used by the MAPBOOK function.
It's one option, the other is to study the help and modify your templates/layouts to exactly meet the specifications.
- alfred -
Alfred NESWADBA
Thanks. That was really helpfull.Smiley Very Happy
