Multi-line text causing crash
Everytime I try to edit, create, or modify multi-line text AutoCAD Architecture 2015 crashes. I have tried uninstalling and reinstalling, and repairing AutoCAD Architecture. I have tried turning hardware accelerator and line smoothing off. Another post suggested that the issue was from computer security so I uninstalled that program; no results. I installed Service Pack 2 for Arch. 2015 and no change.
I don't think the files are corrupt because the same thing happens in a new file. The error has also occured in AutoCAD C3D 2015.
rkmcswain
How about regular text using the TEXT command?
Or things like dimensions, tables, or other objects that contain text?
Do those work okay?
Also, type in the command MTEXTED, and enter the value of "Notepad" (without the quotes) and now try it again..
R.K. McSwain     | CADpanacea | on twitter
Objects and tables seem to have the same problem. The TEXT command also crashes as soon as a begin to type.
The MTEXTED command works. Thank you.
m_kingdon
A strange issue.  Maybe it is something to do with the fonts.
Try the STYLE command to make sure all the fonts are present.  Also, go into Options > Files > Text Editor, Dictionary and Font File Names.  Look at each file path and make sure that I valid file is present (both in CAD and explorer)
Mike Kingdon
Civil 3D Zealot
