multi line mtext in field messed
wesbird
wesbird
I create MTEXT with multi line text, then create another MTEXT, right click, Insert Field ...,
Source MTEXT:
Target MTEXT:
I would want target MTEXT look like exactly same as source MTEXT. what's wrong I have done?
Thank you and have a nice weekend
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
user181
The \ is there because you used the enter key to start a new line of text. If you type all the text without using enter you can restack the text to multiple line by dragging the text box or grips. Then you would restack the target text to multiline the same way.
