Mtxt Boxes squeezing text together when copying from one drawing to another
nfoxJ3N5A
nfoxJ3N5A
Hello. I am having an odd issue I cannot figure out how to solve. When trying to copy text from one drawing to another the Mtxt takes whatever is in the text box and makes it into 2 lines. The text is not set to annotative and I checked all the text sizes and settings and they match between drawings. I cannot figure out what setting is doing this if anyone has seen it. Picture 1 is what the text should look like
and these pictures show what is happening when I copy it
rkmcswain
Is the text style in both drawings the same ? Does one have a fixed text height and the other not? Same font?
I can replicate the error by having the same style in two drawings, each with different settings. (The mtext width property is the same in both)
R.K. McSwain     | CADpanacea | on twitter
nfoxJ3N5A
yeah they had the same text style. IT was the "standard" one that you cannot delete. I checked the settings and it appears they are the same in both drawings. I am not sure exactly why the font is changing we I copied it. I fixed it by just making a new text style and bringing that in.
pendean
Community Legend
Community Legend
@nfoxJ3N5A you will need to share portions of both DWG files so we can investigate please.
Valentin_CAD
@nfoxJ3N5A ,
This will happen if the Font applied to the Standard Style is different in another drawing - as @rkmcswain mentioned.  You just have to pay attention to the details and modify as necessary.
Look at the text from Drawing1 (Using Standard Text Style = Simplex = 0.5 Width) when copied into Drawing2 (with Standard Text Style = Arial = 1.0 Width).
Drawing1
Drawing2
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
