MTP/M2P Command
MTP/M2P Command
nguyendaotai95
MTP/M2P Command
nguyendaotai95
Hi Everyone.
Do you know how to change command "Mid Between Two Point" from "mtp/m2p" to another, such as "mm".
I can not find it in command list.
Thank so much !
vinodkl
Hi @nguyendaotai95
I doubt you could modify M2P to MM to activate the osnap midpoint between two points.
But you assign some accelerator keys to activate that osnap as shown in the screencast below🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ВeekeeCZ
Can't change it to mm.
But there are many alternatives...
Theoretically, we would define some LISP function but that would require to include an apostrophe to run.
So what is possible...
'm
'l
Ctrl+M
Ctrl+Alt+M
or re-map F* key...
add/show an icon
Ctrl+RT click + letter, or click
