Hi Everyone.
Do you know how to change command "Mid Between Two Point" from "mtp/m2p" to another, such as "mm".
I can not find it in command list.
Thank so much !
Solved by ВeekeeCZ. Go to Solution.
Solved by vinodkl. Go to Solution.
I doubt you could modify M2P to MM to activate the osnap midpoint between two points.
But you assign some accelerator keys to activate that osnap as shown in the screencast below🙂
Can't change it to mm.
But there are many alternatives...
Theoretically, we would define some LISP function but that would require to include an apostrophe to run.
So what is possible...
'm
'l
Ctrl+M
Ctrl+Alt+M
or re-map F* key...
add/show an icon
Ctrl+RT click + letter, or click
