When I try to enter (E) Masonry F.Pl.as an example, the text automatically thinks I am wanting Letter dileneators and adds space where I don't want it then when I hit return it auto adds another letter in parantheses, (F) as an example-(see image).
How can I disable this feature. The old MText worked just fine. I am annoyed by how this keeps happening.
Solved by gotphish001. Go to Solution.
If you type (E)+space+backspace it removes the extra space and only puts in one space and it also won't start with (F) on the next line after a return. I know you can click the lightning bolt and shut limiters off for that window, but that workflow is what I do to get around the issue. I just do it as habit now when using (E). I'll see if I can figure out how to shut it totally off.
Nick DiPietro
Cad Manager/Monkey
When you start the MTEXT command, in the text editor box click on the down arrow next to numbering. You can disable bullet and lists there.
edit, once again Dean beat me to the punch.
I was grabbing this capture to explain. It's just what Dean said, but since I already made it. Here it is.
Nick DiPietro
Cad Manager/Monkey
I also found this which seems to shut it off as well. "MTEXTDETECTSPACE" VARIABLE
Nick DiPietro
Cad Manager/Monkey
