Mtext String longer in AutoCAD 2019 than 2018
I have created a drawing in vanilla AutoCAD 2018 with Mtext ....looks great
When I open the same drawing in Vanilla AutoCAD 2019 the same Mtext string is now longer
The properties of the text are identical in both 2018 and 2019
Anyone know why?
BeKirra
I am on 2016. Without looking your file I guess your AutoCAD versions are on different machines.
If this is the case, please check the font used for the same text style in both AutoCAD versions. Iit is probably the font is missing in one of your machines.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Same machine and 2018 & 2019 opened simultaneously
I did attach a file to my original post
cadffm
Then the SHX-Font is missing.
Open your file, look at your TextScreen [F2], isn't there a message for you?
iso3098b.shx
Open file in2018 and look at yout Textscreen, no message about iso3098b.shx?
Search for this font file, type in: (findfile "iso3098b.shx") <enter>
Normally C:\program files\autodesk\autocad 2018\fonts
Copy that file to your 2019 font folder, nomally  C:\program files\autodesk\autocad 2019\fonts
If the message appearing in 2018 too, which font is 2018 use to replace the missing font?
Sebastian
TerryDotson
We have also seen different formatting results in 2019, something changed in that area of the code.  For example it now attempts to show superscript when coming from rich text format (RTF).  I say attempts because it doesn't shrink the height of the superscript portion enough.
