Mtext Justification grip location
kzD1219
Message 1 of 10
kzD1219
I am setting up old text to mtext.  I want to keep the new mtext in line and spaced evenly.  I have the justification to the Bottom left however I end up with the image attached. How do I get the grips to all be at the same location of the mtext?  See how some grips are at the text and others are a little below?  Any way to fix that?
Replies (9)
Message 2 of 10
TheCADnoob
Use TEXTALIGN
First it will do the vertical but you can select options and then choose spacing.
CADnoob
Message 3 of 10
kzD1219
That is a nice command, but we rely heavily on the grip location since we use that spacing and location for things like a legend.  This attached image shows how the text lines up with a pre-made grid. I know I can grab a piece of text at a grip and move it spaced out evenly within grid.
I am looking to update text to mtext on templates I am working on, however is text just as good in a situation like this?
Message 4 of 10
pendean
Community Legend
Community Legend
Why aren't you using a table (with invisible lines) if alignment in legends is so critical? That's how we all do it, relying on floating objects to always perfectly align is not a good way to do it.
Why the move from TEXT to MTEXT? The latter is not an upgrade, the former is not going away ever.
Message 5 of 10
kzD1219
I never set up these legends, so I am not sure why they didn't go with tables.  Good suggestion though.
But thanks for your opinion on text and mtext.  I will probably keep items as text since mtext is giving me a hassle.
Message 6 of 10
TheCADnoob
use the tools for the job they are intended for.
if these are bound in a gird and only going to be single line text i would imagine multiline text (MTEXT) is overkill
That said pay attention to the drawing specs/standards. your company, or your client may require a different type of text for different reasons.
CADnoob
Message 7 of 10
Kent1Cooper
This is a drawback of Mtext, in my opinion, if plain Text will serve your purpose.  It's because of descenders, i.e. the lower-case y that appears in your image, and I would bet that the other ones with the grip below the base-line also have y or g or j or p or q or / or ( or ) or some other character(s) that descend(s) below the base-line.
Zoom in close and start an Mtext command, get into Bottom-Left justification, and slowly type in the word testing.  Notice that the position shifts  as soon as you get to the g -- now the bottom of the object is below the base-line, but the justification uses that bottom of the object.
If you use plain Text, and use [single-word] Left or Center or Right [or Aligned or Fit] justification, not Bottom-Left, etc., then the insertion point will be at the base-line, whether or not there are any descenders.  Mtext does not have those single-word justification options that plain Text has.
Oddly, though, in plain Text, if you use [for example] Bottom-Left justification, it puts the base-line raised as might  be required by descenders, even if there are no descenders  in the content.  Annoying but at least consistent -- Mtext only does that shift if there are  descenders involved, so the same object can have its position shifted just by changing one character of its content.
Kent Cooper, AIA
Message 8 of 10
kzD1219
Yes I noticed that about the descenders.  Text will have to be my go to for now I guess.
Message 9 of 10
TheCADnoob
In properties, try changing the line space style from at least to exactly if you want to stick with mtext and see if it helps
CADnoob
Message 10 of 10
Kent1Cooper
I tried that, but it doesn't.  I do my Mtext that way for other but related purposes, but it doesn't get around the difference between a bottom line of Mtext that has or does not have descenders.
Kent Cooper, AIA
