MTEXT editor slow/freeze after time
Chrishomenko
Chrishomenko
after awhile ( variable time) mtext editor get very slow.
autocad 2022
not drawing specific
uninstall and reinstall cad with default settings
new computer (geforce made sure drives latest)- lots of ram
windows 11- all up to date
only one user having issue. other users with same setup no issues
pendean
Community Legend
Community Legend
Have you seen and worked through these tips yet (you id the last one, but none before that I believe) https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/delay-...
Chrishomenko
yes, should have mentioned tried all those. Seems to be related to plotters- after plotting the behavior persists.
pendean
Community Legend
Community Legend
@Anonymous Do you have background plotting/publishing turned on? Turn those off ASAP, restart your AutoCAD, see if the problem stays away.
Chrishomenko
Thanks pendean, turned off the background plotting/publishing but issue persists.
Guess next step is clean windows install
