Can anyone explain why the below happens occassionaly with Mtext edit, to stop it I am usually having to close & reopen my drawing.
I edit menu seems to just cover the entire screen & you can't actually access the text that needs editting.
Solved by Valentin-WSP. Go to Solution.
Did you change your settings in GRAPHICSCONFIG to begin ? It may work better with craphic card off. A solution for today.
Follow these instructions:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
