MTEXT dialog box is HUGE
travis_reynolds
travis_reynolds
Can anyone tell me how to fix this?  When I use the Multiline Text  command, the dialog box opens HUGE on my screen.  I mean the box to type in is so big I cannot see what I'm typing.  I have to type a couple characters, hit OK, then the text fits in model space at the right size.  Then if I need to edit it, it edits at the correct size in place.  Any suggestions?
pendean
Community Legend
Community Legend
Is this a problem in ALL of your files with all of your MTEXT?
Or is the issue all the MTEXT in this one single DWG file?
Or is this an issue with only this one single MTEXT object?
And how close/far are you zoomed into the Mtext? I can replicate your issue only if I am zoomed in well beyond the ability to read my MTEXT in full for example.
travis_reynolds
After not finding a solution in the forums, I tried Google and found the solution.
After opening the MTEXT command, right-click in the text box, go to Editor Settings and select/unselect WYSIWYG. Problem solved.
pendean
Community Legend
Community Legend
@travis_reynolds wrote:
...go to Editor Settings and select/unselect WYSIWYG. Problem solved.
Glad you found a fix, but that does not do anything here to relocate your initial posted issue in my own MTEXT in my own files. Are there other formatting settings in that MTEXT?
anthony_turner
thanks for this - it was getting on my nerves
Type a product name
