I have a drawing with some mtext boxes with a background mask set to use the drawing background color and they plot to pdf as seen here:
Luckily the same problem does not occur with the publish command.
Even so I would like to diagnose the problem so I have the option of not using publish.
Maybe try these solutions
@jdfnnl ,
Attach the drawing to troubleshoot.
Type ABOUT on the command line and provide us an image.
Check the latest and available updates:
Try the suggestion from these links:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
