Mtext Background Mask border offset factor: Is there variable for default?
rross
Message 1 of 8
rross
Is there a system variable for the background mask offset border distance when using multi line text?
Replies (7)
Message 2 of 8
john.vellek
Hi @rross,
I am not aware of a variable that controls the offset of the border for the mask.  Reading through some things I found on the web, it appears that you can adjust this using lisp or through VBA. Would you like me to move your thread to the customization forums?
John Vellek
Message 3 of 8
jayhar
Background Mask Dialog Box
http://help.autodesk.com/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-3448A24E-E18B-4C8C-B8AB-84F4CD4E...
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved. ?
Thanks You
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 4 of 8
j.palmeL29YX
I don't think so. It is a property of the MText object.
If you are familiar with LISP maybe this informatuon will help you:
DXF-Group code 45 is for the scale factor of this "mask offset" (more precise:  it is a scale factor, depending on the text height).
cadder
Jürgen Palme
Message 5 of 8
j.palmeL29YX
Correction:
It (the default value) is stored in the registry in the environment variable "TextMask_BackgroundScale".
cadder
Jürgen Palme
Message 6 of 8
john.vellek
Excellent discovery.....I did some searching in the registry but apparently I didn't search hard enough!
John Vellek
Message 7 of 8
Can you explain what "stored in the registry" means? Is that something accessible that I can change?
Message 8 of 8
j.palmeL29YX
You can - if you know what you do. But if you don't even know what the registry is you SHOULD NOT DO IT. You can destroy your system.
FYI: In the WINDOW folder of your OS you find a "regedit.exe". This starts the Registry Editor which can used to modify a lot of settings on your computer. But I repeat: Don't do any changes here if you don't be sure what you do.
Jürgen Palme
