Announcements
Moving Multiple Attributes in Multiple Blocks
cmulligan
cmulligan
I need to move the labels for many blocks at the same time while they are stacked.
There was a feature in 2014 that I used often but I cannot make it work in 2016.
To explain the situation, I have 20 blocks representing a linear light fixture. I need the label on each of them for information in data exports to excel, but I only need one label to appear on the drawing.  In 2014, I was able to stack the labels from the 20 fixtures in the same position (AutoCAD neatly snaps them together). From here I could select all the blocks from this "single" label and make edits to all of them. This is still works in 2016 of course, but I was able in 2014 to use the move grip over this label to move of them at once.
Currently, I can stack them, but once I select them all and try to move, it pulls the top label away from the group.
Is there a setting that I need to turn on for this to work?
pendean
Community Legend
Community Legend
Show us a dwg file with this content please
RobDraw
What you are describing as the new behavior is how I would want and expect it to work. Maybe it was a bug that happened to give you the desired result but was not the way it "should" work.
Rob
cmulligan
Dean,
After copying fixtures from an old file, I realized it wasn't a problem with 2016.  And then after I deleted all but one of the blocks and made a duplicate array, I was able to achieve the desired function.
So this isn't solved, but it seems like it could have simply been a bug.
I've attached the file that has two rows of blocks - the one that works and the one that doesn't. I can't see any difference in properties between them.
Be sure to select all in the row before moving the label.
Thanks for your reply!
pendean
Community Legend
Community Legend
Select your first row: start PROPERTIES. Note POSITION Z says varies.
Do the same for the second row: POSITION Z has the same consistent setting for the entire row.
You forgot about the Z direction in the XYZ location any object can be in AutoCAD/LT.
cmulligan
That'll do it.
Thanks!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
