cmulligan
2886 Vistas, 5 Respuestas
Moving Multiple Attributes in Multiple Blocks
I need to move the labels for many blocks at the same time while they are stacked.
There was a feature in 2014 that I used often but I cannot make it work in 2016.
To explain the situation, I have 20 blocks representing a linear light fixture. I need the label on each of them for information in data exports to excel, but I only need one label to appear on the drawing.  In 2014, I was able to stack the labels from the 20 fixtures in the same position (AutoCAD neatly snaps them together). From here I could select all the blocks from this "single" label and make edits to all of them. This is still works in 2016 of course, but I was able in 2014 to use the move grip over this label to move of them at once.
Currently, I can stack them, but once I select them all and try to move, it pulls the top label away from the group.
Is there a setting that I need to turn on for this to work?
