Move Text or Layer to Top
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Given:
AutoCAD 2019
Win10
Multiple layers setup
I am trying to place a wipeout polygon above some layers and under others such as text.
Procedures in a Layout:
- Create text on a Text layer
- Create a wipeout polygon over part of a drawing
- Text is hidden behind the wipeout
- Hide Wipeout layer
- Select the text that was hidden under the wipeout polygon
- R-Click - Draw Oder - Bring to Front
- Now the text is visible and you can Output a pdf of that layout and the text is visible over the wipeout as expected. That is what I want!!
Problem:
- After switching between Layouts (multi-layout dwg) text or other items that were move “to top” are lost behind a wipeout polygon.
The position setting is not be retained. I need specific layer to be overtop of others. Text, dash lines and other annotation, in this application. I am not clear about how to move specific layers to display above another layers? And/or is there a way to ensure that the items such as text stay after moving them to the top?
Kevin
