MOVE command shortcut?
joe_kohli
Message 1 of 11
joe_kohli
I upgraded to a gaming mouse with programmable buttons and it has been quite helpful in the use of AutoCad, however, is there a shortcut for the "MOVE" command? This would be so nice to have instead of having to type "M" in the command bar and then hitting enter. I'm running 2022
Replies (10)
Message 2 of 11
paullimapa
Perhaps it’s possible to program your mouse so that one of the buttons does a M and enter? Btw you can also hit the space bar as an enter since it’s just right below the letter M
Paul Li
IT Specialist
@The Office
Message 3 of 11
VincentSheehan
What brand mouse is it? Are you asking to assign move to a mouse button? Can you assign MOVE or M command to a button using the mouse software?
You could also create a MOVE shortcut command and a Shortcut Key in the CUI.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 4 of 11
joe_kohli
Logitech G502. Yes, I basically want the scroll button to the left to act as a "MOVE" command. I don't see any MOVE commands in the CUI.
Message 5 of 11
Patchy
Nothing can be done with CUI you have to use the mouse driver that came with your mouse.
Message 6 of 11
joe_kohli
So what should I set my mouse to? "cntrl + M" or what shortcut control do I need to use to apply to my mouse?
Message 7 of 11
pendean
Community Legend
Community Legend
@joe_kohli Short answer, no, your mouse button software does not know how to activate an AutoCAD command, and CUI command does not have hooks into your mouse driver to override the mouse driver.
But... your mouse driver has many keyboard button functions that can be assigned to the buttons you want to customize: find those key combos, set each button to a different one, then use CUI command to assign MOVE to one of those key combos (assuming it is not doing anything else).
Just remember, in ALL programs on your PC, an in windows, those buttons are going to activate that keyboard key combo all the time. So choose wisely.
Autodesk offers this very abbreviated post on the topic
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Assigning-AutoCAD-....
And don't be fooled by this find in CUI command, it's a legacy leftover for those still using old-school tablets from decades ago, it's non-functioning for modern mouse/drivers.
HTH
Message 8 of 11
Patchy
Just M
Use text as shown here about 2:00
https://www.youtube.com/watch?v=LL1fPKsoN4o&t=126s
Message 9 of 11
VincentSheehan
You should be able to assign commands using the Logitech G-Hub software. I have a Logitech gaming keyboard with 18 G-Keys and I have assigned AutoCAD commands to them using the Logitech software only. It should be the same with the mouse but I could be wrong.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 10 of 11
adrian_cruz-pc
Hello, I use the logitec g305 (or use to, THE SCROLL WHEEL wore out, another story...)
But it is possible to enable the move command, just need to assign a macro using the software that came with your mouse.
This is a screenshot for the logitech area I made my move command. After I typed the command, I literally had to press enter (note enter is not shown for the software I am/was using).
Then after I made the macro, I assigned it a hotkey.
note sure which mouse/program you are using, but I'm sure it's possible with any gaming mouse you can assign macros.
@adrian_cruz-pc - this post has been edited due to Community Rules & Etiquette violation.
Message 11 of 11
CGBenner
@joe_kohli Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
