Drawing commands not working
andra_butler
andra_butler
Community Visitor
Community Visitor
NONE OF MY DRAWING COMMANDS ARE WORKING. ´L´NOT DRAWING ANY LINES, RECTANGLE NOT DRAWING ANY RECTANGLES.
Valentin_CAD
@andra_butler ,
Welcome to the forum.
If a RESTART does not solve the issue, consider checking required AutoCAD UPDATES or the suggestions in this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Kent1Cooper
Does it work if you type in the full and actual command names -- LINE and RECTANG in those cases -- instead of aliases or stand-in names?  If so, my guess is that your acad.pgp file that defines command aliases has gotten misplaced to somewhere that AutoCAD does not know to look, or perhaps deleted.
Kent Cooper, AIA
pendean
Community Legend
Community Legend
paullimapa
So AutoCAD worked before and then suddenly none of the commands work?  Was there something that happened right before it stopped working?
Paul Li
IT Specialist
@The Office
puttykey2024
Try to restart the AutoCAD and then retry to use drawing command.
