Move Command Malfunctions
I have been encountered "Move Command" malfunction on several occasion..
Problem Statement:
First: Object to be moved is selected.
Second: Typed "Move" Command in command bar. Then pressed "Enter"
After pressing "Enter", I found that the object earlier selected has been deselected after the command.
Any solution to the above problem, kindly reply.
Vinayv4v
Make sure your PICKFIRST variable is set to 1.
Cheers,
Vinay Vijayakumaran
ian.mag
Hey @Anonymous,
Make sure that noun/verb selection is checked in the options>selection tab
gotphish001
Pickfirst and the noun/verb check box are the same variable.  When you change pickfirst it changes if the box is checked or unchecked.
Nick DiPietro
Cad Manager/Monkey
ian.mag
Hey,
That's correct, but one is through command alias and the other one through the shortcut menu, but pretty much the same
gotphish001
Always multiple ways to change settings that also can get confusing. Just didn't want the OP to try changing both suggestions at once and end up fixing it by changing one way but then going to the other setting and changing it back effectively breaking it again.
Nick DiPietro
Cad Manager/Monkey
