Error Code Number is 107028 with AutoCAD Sweep
I'm trying to extrude a solid with the sweep cmd but get "modeling operation error: error code number is 107028 unable to sweep 1 selected objects"
The sweep object is a simple rectangle, path is a 3dpoly.
Is anyone familiar with this error number?
Fred
@Anonymous,
john.vellek has edited your subject line for clarity: Error Code Number is 107028
john.vellek
Hi @Anonymous,
The error codes don't mean much to those of us using the program (only the developers get some benefit).
Try simplifying your 3dPoly or try converting it to a SPLINE for the sweep.
You are welcome to attach the drawing to a post so I can take a look.
If your data needs to be private or confidential, please email it directly to me at [email protected] and please include a link to this thread in your email.
John Vellek
john.vellek
HI @Anonymous,
Did you try this again using a spline? If you are still having trouble getting it to sweep, please share your file so I can take a look.
John Vellek
Thanks for the ideas.  No, these are utility lines on an industrial site and not something I can spline.  I did find if I offset my centerline 3dpoly to the "inside" of the 90s it would extrude along the path.  Currently I'm trying it as a corridor model with custom assembly/subassemblies to see if it yields the desired results.
Thanks again.
@john.vellek wrote:
HI @Anonymous,
