Move and Rotate issues
I'm running into a problem. When I right click and select rotate, as soon as I pick my point it rotates on its own. When I right click and select move, as soon as I pick my point it unhighlights the objects.
Strangest part is, if I type move or rotate in the command it works just fine. Everything was working no more than 30 minutes ago.
Thanks!
fatal.error
Have you checked if PICKFIRST is set to 1 and SHORTCUTMENU to 11?
imadHabash
if you change your mouse with another one , any changes ?
Imad Habash
