mouse and keyboard trouble working with dual screen
Hi I am having a few issues with a delay on a Dual screen setup in the office. When she moves the AutoCAD window from the right screen to the left screen there is a significant lag as well as the mouse and keyboard are having issues with delay. Hardware acceleration is enabled and the computer is well equipped to run the program.  any ideas what could be causing it? thanks in advance for the help
pendean
Community Legend
Community Legend
PC specs?
Windows version?
Video card? Video card driver version is?
AutoCAD version?
Dell 3620
ram 16gig
nvidia k2200
windows 7
Autocad p&id 2014
She usually has multiple windows open and other programs as well could that be the problem? Maybe an issue with her ram or desktop not being able to process everything?
another thing is that she uses a logitech mouse and keyboard but ive uninstalled the drivers, the ones active are the HID-compliant mouse/keyboard
pendean
Community Legend
Community Legend
Thanks: those are pretty 'normal' PC specs and very similar to ours, so I see no reason for the lag when moving across as described. You also ruled out keyboard and mouse drivers too.
Does turning off hardware acceleration in AutoCAD do much to improve it? I suspect not but since you mentioned it was active .... .
no the Hardware acceleration barely made a difference if any at all. I'm assuming it could just be an issue with ram. Her coworker has a nvidia k4000 and 32g of ram and runs more autodesk windows as well as the other programs they use daily with no issue. Her monitor is a sharp TV and is also set to 1920x1200 do you think that could affect it as well.
pendean
Community Legend
Community Legend
Yes, upgraded system components do make a noticeable difference.
