Monochrome.ctb not plotting correctly in ACAD2024
martin.mardikas
martin.mardikas
Hello!
I started to use ACAD2024.
Now I need to plot first drawings into pdf.format.
I'm using monochrome.ctb , meaning everything is black.
So I  layers have different lineweight values .
But if I plot to pdf, all lineweights are in same thickness.
Couple of settings:
1) plot settings
2) monochrome.ct settings
3) layers settings
4) lineweight settings
I will attach file as well, if helps.
But what seems to be the question? Something to do with ACAD2024?
Thanks!
Valentin_CAD
@martin.mardikas ,
No issues, just use a different lineweight. (See PDF attached).
Also, consider using the DWG to PDF.
(May want to perform an AUDIT too)
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
martin.mardikas
What kind of lineweight you used? Because i used 0.13 and 0.3 thickness. And i printed out and couldn't see the difference
Valentin_CAD
The ones shown on the Lineweight Settings:
Try plotting with the DWG to PDF as mentioned.
It could be your CTB is damaged (see link below or the attach file).
Emilio Valentin
Type a product name
