AutoCAD Forum
modemacro startup autocad
4 REPLIES 4
kidznok
397 Views, 4 Replies
How can I start autocad with modemacro $(getvar,dwgname) ?
I know that I can put it in filepath but only scr for example "/b nameofscript" , but how add only modemacro command not whole script?
4 REPLIES 4
cadffm
in reply to: kidznok
You can use this way you talked about, create a *.scr file with
_.MODEMACRO<enter>
$(getvar,dwgname)<enter>
as content.
Or you can use  ACAD.lsp file, add
(setvar "modemacro" "$(getvar,dwgname)")
(ACAD.lsp is a userdefined file, not part of a standard installation, search for ACAD.LSP to learn more about it, if you don't know)
Sebastian
Thank you very much 🙂
kidznok
in reply to: cadffm
Thanks.
One more question - how to add this scr when I start from file not from shortcut of AC ?
cadffm
you can't
For this you should go the other way - use ACAD.lsp.
1. Search foir existing ACAD.lsp:
  Command: (findfile"ACAD.lsp")
  If you got a path, open this file and add what i wrote above.
  If nil, go to 2.)
2. Do you have your own AutoCAD Support folder for company or personal AutoCAD stuff?
    If not, create such an folder, and add a text file like your *.scr file, but this this name and extension: ACAD.lsp
    File content, look above.
    Now, add this folder as AutoCAD Supportpath to your profile.
     Command: OPTIONS, FILES tab, first node - add your folder path there and re-start AutoCAD.
Sebastian
AutoCAD Inside the Factory
