Modelling a hollow cylinder with a spiral top
rb26d3tt
rb26d3tt
Hello.
I need help modelling a cylinder with spiral top.
In the attached file you can see top and bottom of the cylinder and how it looks unfolded.
Top is made with two helixes (cylinder wall thickness 2mm).
Replies (10)
Patchy
You need 2 helices for Guides
Loft the rectangular shapes
then Slice the bottom to get it flat.
rb26d3tt
Thanks for the reply!
Is there a way to get rid of the seam? It must be a solid cylinder.
Patchy
Yes.
rb26d3tt
I'm fairly new to AutoCAD. Would you mind writing a detailed instruction on how you did the whole thing?
Patchy
You can tinker with the drawing.
Use LOFT command, and pick 2 rectangles then use Guides line (Top and bottom helix )
when you get stuck, post your questions here.
rb26d3tt
It worked. Thank you very much.
rb26d3tt
Ok, I did ran into some issues. I'm trying to skip the slice part and start with a circle base and a helix top.
However I can't choose both helix arc and circle arc as guides. Getting 114066 error.
If I pick one of them as a guide the shape is slightly crooked.
Patchy
It works for me, maybe I was using the rectangles as closed 3dpolylines instead or regions as you had.
rb26d3tt
I'm having a weird glitch when trying to do so on a high enough cylinder.
Have I encountered a limitation on the command?
Patchy
I only can open 2007 version.
