I get an error code: The Boolean operation on solid and/or surface bodies failed.
Modeling Operation Error: Error Code Number is 18026
First, I did 10000 on Twist and it worked. Now I want 10000 and it will not work. But if I do 8000 it will work but I need the 10000 for look I want to see.
This message is an old one, but it was never really solved so I re-posted my drawing to this one. I am using the SWEEP command with a TWIST at 12000. Then I EXTRUDE a small diameter along the same Path then copy the last one at 0,0 so I don’t lose what I just Extruded. Then I Subtract the smaller extruded part from the twisted part. Error Code 18026 appears. It worked in my other drawing with a straight down and right angle at the bottom (conduit on the right). So, I gave up on the Subtract and said Merge the Twist and Straight and same error code 18026 appears.
My objective is shown in the one on the right. I have a 1” conduit and I made a rectangle and SWEEP TWIST 12000. Then I use a .99 conduit and extrude or sweep that part. Copy that at 0,0. Then I Subtract the .99 from the 1” twisted part. Then I merge the twisted part with the .99 extruded part. All worked for the right side one but not the ones on the left.
So, I do the Twist again on the one in the middle and I get an Error Code 115073 and it won’t twist.
I am using AutoCAD 2025, all updates have been updated. I even went back to 2024 and tried and the same happened.
I know this is a lot to follow. But any ideas would greatly be appreciated.
Thanks, JRR.
