My model space is set to 1:40
My Paper Space is set to 1:40
The Page setup for the Layout is 36X24 inches.
And the Plot scale is set to 1:20 (It seems to be what makes the title block fit into the printable area).
When I open a viewport in paper space, I set the viewport scale to 1:40
The job is about 50 times smaller than it should be on the title block.
This job should be taking up 2 sheets at least at a 1:40 scale.
Can someone tell me what's going on?
Solved by imadHabash. Go to Solution.
>> The job is about 50 times smaller than it should be on the title block. <<
when you're printing from paper space scaled VP make sure that your scale in the plot dialog is 1:1 or 1:0.10 or 1:100 depending on your drawing units because your needed scale is already prepared in your VP .
Imad Habash
