MODEL DISTORTS as I rotate the view in viewport
I'm having trouble with the distorted view as I rotate within a viewport. Usually I don't get this issue but I'm having one right now. Please do share your thoughts if this one has solution.
Alfred.NESWADBA
Some questions:
  • Do you rotate the model or do you use a command that changes the view, like orbit or so?
  • Can you show a screenshot so we can see how your model looks ok (or a DWG-file from that) and how it looks like when it's distorted?
  • Which version of AutoCAD are you using (please a screenshot from dialog/command _ABOUT)
  • Does the same happen, when you turn off hardware acceleration (command _GRAPHICSCONFIG)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
