MLSTYLE
MLSTYLE
MLSTYLE
DEAR SIR/MADAM
I want to ask you something i create an MLSTYLE with the name AlIKI .You can see it from the screenshot.
I want to make some changes but i can not because the button Modify is not enable ,with other words i can not press it.
what i should make now in order to fix the problem and to make all changes in the Style ALIKI that i want?
Sofia.Xanthopoulou
Gia sou Aliki,
if you have any objects in the drawing, using this style you cannot edit the style.
Erase the objects on this style, or set them to another style. Then you should be able to edit the style.
Let me know if it worked out.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Mrs Xanthopoulou
YES ,I UNDERSTAND where was my mistake and i fixed it.
thank you very match!!for your answer
Ι made this question because i was watcing a tutorial video with the name
Multiline, multiline style and multiline edit commands of Autocad
and i did not not notice a detail!
