AutoCAD Forum
Mline unique selection
5 REPLIES 5
597 Views, 5 Replies
I just imported thousands of contours from a local municipality. Is there a method to select contours at every 5 feet (ala 5', 10', 15'...etc.)? I need to have major (5') contours on a different layer (lighweight). It will take forever selecting each 5' mline.
BTW, using AutoCAD 2014
5 REPLIES 5
sthompson1021
sthompson1021
 Do the contour lines have a Z elevation attached to them? If so you might be able to isolate them using QSELECT. Are they true MLINE's ?
Patchy
Patchy
Try Qselect or use Front View and select by crossing them.
in reply to: sthompson1021
They are multilines with z elevations, but they are not true 3D mlines.
Qselect does not give you the option to isolate by elevation.
Any other ideas?
Any other ideas?
Kent1Cooper
Kent1Cooper
On the assumption that they're really Polylines [it's hard to imagine using MultiLines for contours, but change the entity type below to whatever they really are], and that they have 3D elevation, here's one way [lightly tested]:
(if (setq contourss (ssget "_X" '((0 . "*POLYLINE") (8 . "YourContourLayerName"))))
  (foreach contour (mapcar 'cadr (ssnamex contourss)); selection set to list
    (if (equal (rem (cdr (assoc 38 (entget contour))) 60.0) 0.0 1e-6); five-foot-multiple elevation
      (command "_.chprop" contour "" "_layer" "YourFiveFootMultipleContoursLayerName" "")
    ); if
  ); foreach
); if
EDIT:  Sorry -- that won't work for Mlines [they don't store their elevation as Polylines do].  If they're level, try this substitution:
(if (setq contourss (ssget "_X" '((0 . "MLINE") (8 . "YourContourLayerName"))))
    (if (equal (rem (cadddr (assoc 10 (entget contour))) 60.0) 0.0 1e-6); five-foot-multiple elevation
Kent Cooper, AIA
    ); if
  ); foreach
); if
Kent Cooper, AIA
hgasty1001
hgasty1001
If the drawing was generated in Autocad Map, the contour lines could be mpolygons, can you post the result of this? : (cdr (assoc 0 (entget (car (entsel)))))
Gaston Nunez
Gaston Nunez
AutoCAD Inside the Factory
