AutoCAD Forum
Mline question
6 REPLIES 6
497 Views, 6 Replies
Mline question
I am using autoCAD 14 LTE and i cant use multilines. I remember being able to use it in 2013. Was ML taken out? I cant even edit ML's.
Tags (3)
6 REPLIES 6
pendean
There is no MLINE in AutoCAD LT, never has benn, still isn't available. part of the discount you are enjoying.
Look into DLINE command (limited to two lines) and offset/fillet as needed.
in reply to: pendean
Thanks I appreciate it alot, i figured it was something like that. i have been using Dline for the project I am on at work, i own have a student copy of 15 at home. so i guess i got a second question, if i draw a multiline at home and bring it to work on a flash drive can i copy and paste the DWG into my shop drawings? or would i need to get a full version and a seat at home?
pendean
LT should honor whatever you create in full AutoCAD: it just won't let you edit them like you can with MLINE command for example (changing styles, adding segments etc.).
It is my understanding that, even though 2015 doesn't plsce a plotstamp on EDU created dwg's any more, it is still against the EULA to use EDU software for comercial purposes.
Thanks I appreciate it, so question number too, if i have a sear at my job can i use that seat at home?
If you are on subscription you should be able to take advantage of the home use policy.
AutoCAD Inside the Factory
