Missing SHX Files
Missing SHX Files
Jendapen
Missing SHX Files
Jendapen
Hi!
I have installed a new version of autocad. When I opened a file I got this message but I happened to press "Specify a replacement for each SHX file" and checked "Always perform my current choice" Can you change the selection to "Ignore the missing SHX file and continue "?
vinodkl
Type in the command "OP" and then select the system tab and then click on the "hidden messages settings" which would open up another window and here you need to check mark the " missing SHX files" and apply the settings.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
