Missing Open File Tabs
MarkFitz
Message 1 of 10
MarkFitz
Hi Folks,
Something has happened with my PC and my ACAD screen setup has changed, I no longer see the toolbars on the left side of the screen, actually, I no longer see toolbars at all, and the tabs along the top, under the ribbon that show which drawing files I currently have open are gone.  Also, the ribbon only shows tabs as titles, no buttons.
How do I get my workspace back?  (I tried switching between workspaces, but that didn't have any effect.
I don't want to think that someone has purposely tampered with my PC, but my office light was also on this morning when I arrived.  I'm more concerned with getting my ACAD setup back.
Any suggestions?
MarkF
Replies (9)
Message 2 of 10
TomBeauford
2 tips to avoid it happening again.
1st Keep "Save Workspace Settings" turned off so if they accidentally get changed they won't get changed when switching Workspaces. So switching to another Workspace then back again will usually restore them.
2nd When you have your Workspace set how you want it save it as a backup Workspace with a different name.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 3 of 10
imadHabash
I suggest to follow this  LINK that may help .
Imad Habash
Message 4 of 10
Valentin_CAD
@MarkFitz ,
@MarkFitz wrote:
... I no longer see the toolbars on the left side of the screen, actually, I no longer see toolbars at all, and the tabs along the top,
... the ribbon that show which drawing files I currently have open are gone.  Also, the ribbon only shows tabs as titles, no buttons.
These links will help:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 5 of 10
chriscowgill7373
@MarkFitz can you provide a screenshot of what you are seeing?  sometimes just providing a picture can help generate an answer a whole lot faster than trying to describe your issue.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 6 of 10
MarkFitz
Here are the before and after (ignore the text in the before pic, that was from a previous question, I just happened to have and old screen shot of this)
ACAD Setup is the after
ACAD Workspace is the before, i.e. what I would like to get back to.
Message 7 of 10
pendean
Community Legend
Community Legend
This is a toolbar: simply reverse the process that you followed to get rid of it?? Do you need help finding that previous post of yours?
To turn a toolbar on, you simply restore the WORKSPACE you saved previously when you set it up. Don't know how to do that? Try this
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-51E1D144-1EC4-4B4B-B4FA-F8456D40A4AF
Forgot to do that? You can follow this instructional guide from Autodesk
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/how-to-turn-toolba...
And don't forget to...
Message 8 of 10
MarkFitz
I went through the different saved workspaces I have on Friday, and didn't see what I was looking for.  I just ran through them again and found something that is just about what I had, so I'm sticking with that.
Thanks to everyone for all your help and suggestions.  Now that I have this back, I'm a little curious to know how it happened, I mean, I'm not important enough to warrant professional sabotage, I am but a humble drafter...   I got my workspace back, I'm satisfied with that.
Thanks again, guys!
Message 9 of 10
chriscowgill7373
It is very easy to accidently click off on something.  One thing I would recommend is setting LOCKUI to a value of 15.  Then you have to hold ctrl while clicking to drag something.  It doesnt help with the ribbon though, you would still have to click back through to cycle the various options.  I cant say that I have ever accidently minimized my ribbon, but I dont have MENUBAR turned on, so I have no business clicking that far to the right.
Message 10 of 10
MarkFitz
Thanks Tom, good points, duly noted!
