Missing arrows option to navigate to other Layout tabs
WJon01
Message 1 of 11
WJon01
Hi All,
This is a minor issue but annoying.
This drawing I am working on has 20 Layouts. The arrows pointing down which you use to switch between layouts is missing? How do I get it back?
This is the case for all files I open and this is my preferred method of navigating the various layouts.
I am using full AutoCAD 2024.
Kind regards
Replies (10)
Message 2 of 11
Valentin_CAD
@WJon01 ,
This feature has changed in AutoCAD 2024 - see link:
New:
Previous versions:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 11
ВeekeeCZ
You DON'T!
Please report this HERE to let them know they should finish the job.
Unfortunately, the same thing happens when it comes to filetabs.
Message 4 of 11
pendean
Community Legend
Community Legend
@ВeekeeCZ @WJon01 That changed in the program, it is now here (see below) and you cannot put it back to the old style in the program
Message 5 of 11
ВeekeeCZ
@pendean you're missing the point. As much as I don't like that now it's unnaturally on the left, the main issue is about missing a visual indicator that there are more tabs than it shows.
Message 6 of 11
pendean
Community Legend
Community Legend
Then you need to tell Autodesk abut it where they look for feedback from users like us, here
https://www.autodesk.com/company/contact-us/product-feedback
Not in these forums.
Message 7 of 11
ВeekeeCZ
Sure, I did a long time ago. Also encouraged the OP to do so as well.
Message 8 of 11
WJon01
I feel your pain. It is un-natural to start going to the left instead of the right.
Also have an 2018 session so it is the other way round.
Thank you for confirming though.
Message 9 of 11
pendean
Community Legend
Community Legend
Once? a long time ago? If you feel truly passionate about it that needs to happen often and regularly in addition to you encouraging others (with obvious links vs. hyperlinks in these display-lousy forum text defaults, like I did responding to you) to do the same (be seriously obvious, not 'techy' LOL).
Message 10 of 11
WJon01
I appreciate every one taking the time on this topic. We worked out it wasn't just me going MAD.
Thank you all and Happy Halloween  👐
Message 11 of 11
jeannine_mattison
Observer
Observer
there is a massive sign up process to leave feedback. I just want my arrows back!  The new system is so much clunkier to navigate!
