Missing 3D geometry
Missing 3D geometry
anderson51
Message 1 of 8
Missing 3D geometry
anderson51
I am running 2018 Vanilla
Client is running 2014 Vanilla
When they open the .dwg  3D geometry is missing and the following message appears in the command line for each missing item:
Modeling Operation Error:
     Save file is from a later version of ASM.
All geometry was created with 2018 Vanilla.
Any ideas?
Replies (7)
Message 2 of 8
DarrenP
2018 is a different file format from 2014
you will need to save down to the 2013 file format
DarrenP
Message 3 of 8
anderson51
The file is saved as 2013
Message 4 of 8
cadffm
It is the internal Modeling core, that changed and your message looks like.. it isn't compatible in every case.
Search for this paper in english
https://knowledge.autodesk.com/de/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/DEU/Au...
Google for? New features 2018.1 autocad 2018
or ask in the .net / arx Forum here to get more informations(without a solution?)
I would only try one thing: From the newer Version, -exporttoautocad
Perhaps @john.vellek have more informations about sharering between versions and the ASM
A (simple) sample file could be helpful.
Sebastian
Message 5 of 8
cadffm
One test please, only for me.
Open your file in 2018 and type-in
(Sslength(ssget "_x"))
Open the SAME file in 2014, do the same.
Is the result in 2014 a lower number?
Sebastian
Message 6 of 8
john.vellek
Hi @anderson51,
This is an interesting issue. I have not seen this error but I guess it does not take me by surprise.  I imagine certain types of geometry from the current ASM might not be backwards compatible.  This would especially be true if you were using Viewbase which relies on the Inventor engine.
I created some simple geometry in 2019 product, saved down to 2013 format and had no issue so I suspect this is geometry-type specific. Can you share one of your files so I can explore this issue?
John Vellek
Message 7 of 8
dmfrazier
I have some drawings that are exhibiting the OP's "Modeling Operation Error".
I ran your little LISP snippet with one of these files in 2018 and 2014 and the number returned was the same.
Message 8 of 8
dmfrazier
Have there been any further developments regarding this issue?
