Mirroring in Autocad without additional linework
aliasnasrat
Message 1 of 9
aliasnasrat
Considering the floor plan arrangement shown in picture1.
You need a mirror line to create the right-hand floor arrangement shown in picture2.
Which tool option below should I use to make sure the mirror line is centered between the two wall lines without adding additional linework?
Here are the options:
1. Mid Between Two Points (M2P)
2. Intersection (INT)
3. Midpoint (MID)
4. Endpoint (END)
Here is picture1
Here is picture2:
Accepted solutions (3)
Replies (8)
Message 2 of 9
imadHabash
it seems that you have a kind of exam some where !!!
Any way ... the answer is Mid Between Two Points (M2P) .
Q: did you know why M2P is the right answer ?
Imad Habash
Message 3 of 9
RobDraw
You gave him an answer even though you knew it was an exam question? SMH...
Rob
Message 4 of 9
aliasnasrat
I usually mirror objects in autocad by drawing a line then use end point or mid point snap to mirror. I tried using all the options in autocad except the M2P. I also already knew the correct answer but I could not find M2P or even MTP in the osnap setting. That is why I was confused as to why the correct answer is M2P if there is not even a snap that I can see in autocad called M2P.
Here is a picture of osnap setting but there is no M2P in there:
Message 5 of 9
Kent1Cooper
You're in the wrong tab.  You want the Object [without the 3D] Snap tab:
Kent Cooper, AIA
Message 6 of 9
aliasnasrat
I tried the other tab too. I still do not see M2P. Here is a picture of the other tab you highlighted.
Message 7 of 9
RobDraw
It cannot be a running object snap. It is accessible in the same way you normally activate temporary/non-running snaps.
Rob
Message 8 of 9
imadHabash
You can hold [shift] then press right button mouse ( Shift + Right click )  then choose it from the list . M2P is consider as a command modifier that can be used with running object snaps or object snap overrides.
Imad Habash
Message 9 of 9
aliasnasrat
I see it now. For some reason, I did not see it when I was Shift + right-click for snap points so I started looking for it in the snap setting. Also, I was expecting the name to be M2P so maybe that is why I did not see it initially.
Thank you for the clarification.
