using AutoCad 2020.
When you using mirror command (with 3D objects) it does mirror only partly.
Some faces (and lines) are mirrored, some not. If you cancel, it cancel also partly, but you can´t go back to the situation before the first mirror command.
(It even leaves some faces visible - after the cancel - but you can´t select them, redraw doesn´t help)
Known issue?
WR
Lasse
