Mirror command not working in proper way
info42JKJ
info42JKJ
using AutoCad 2020.
When you using mirror command (with 3D objects) it does mirror only partly.
Some faces (and lines) are mirrored, some not. If you cancel, it cancel also partly, but you can´t go back to the situation before the first mirror command.
(It even leaves some faces visible - after the cancel - but you can´t select them, redraw doesn´t help)
Known issue?
WR
Lasse
imadHabash
HI,
are you using MIRROR3D command ? does the same happened with it or not ?
Imad Habash
j.palmeL29YX
Post an example dwg please.
Jürgen Palme
info42JKJ
I did use both normal and 3D. Same result.
But I did reinstall Autocad 2021 as total new installation.
Now it Works.
Thanks and sorry about the whole thing.
WR and stay safe!
